Good evening, บุคคลทั่วไป
  • 760
  • 0
เมื่อ: 22 สิงหาคม 2019, 09:17:48
  • กระทู้: 13
The Only Holy Grail to Turn Your Baccarat Losses Into Future Wins
There really is a holy grail to beat Baccarat! There is no mechanical system nor should you ever pay for a holy grail! This article is to provide you with the tools to recoup your losses in the Baccarat game. So you loss $10K - $100K allnewเว็บหัวควย พ่อง this year or through the years you've been in the Baccarat game? Well, you can surely recoup all your losses in small increments. The goal is to win several units for the day, such as 3-6 units. You will not be able to win everything back in one shot because that is not a smart move to wager big increments, for you can lose it all in one wager. Follow these simple rules and you will win more than you ever have.
The Rule of
1. First wager, you must only wager the table minimum.
2. If you lose the first wager, sit out and wait for the right time to jump back into the game. If you win the first wager, sit out and wait for the right time to wager again.
3. Do not drink alcohol when you are playing, for it will cloud your judgment.
4. If one TIE comes out, wager the table minimum for a Double Tie.
5. When you are on a hot streak, wager big **up to your discretion**
6. Once you win several units or win at least 50% of your initial bankroll, leave the table.
7. If you win at one  , allnewเว็บหัวควย พ่อง on the same day, do not go to another   to play, you will 70& of the time lose what you've won at the first   to the second one.
8. Rule #8 is, you must follow the rules above in order for you to win, if you don't, you will guarantee LOSE.
Never use other peoples so-called winning-baccarat systems on the forums or purchase from the internet, for 99% of the time, you will lose. Find your own system and use the Rule of 8 to refine your Baccarat game play. If you choose to play the game to make a profit, allnewเว็บหัวควย พ่อง then these are the only set of rules you will need to follow. When I say set of rules, it is the key to beating baccarat. Believe me and you will win.
Rule 1 + Rule 2 + Rule 3 + Rule 4 + Rule 5 + Rule 6 + Rule 7 + Rule 8 = Holy Grail to Beating Baccarat.
